Will these wheels on Ebay fit my LS?
the staggered fitment might be a problem, and it depends on the offset, for instance, when people buy most of the jag wheels, they need to buy four fronts because the back wont fit right.
+1 LoudLS. The back rims have too low of an offset to fit the LS. Those will probably be the same offset as the Sentas or any other 20 X 8.5/20 X 9.5 Jag rim combo.
And you might rub 20" is pushing it.
I know up to 22" will fit but thats gotta ride really rough with no tire.
Depends on two things. If you're lowered, and how motivated you are to get them to fit in the rear. It seems like many around here are afraid of rolling or pulling fenders or even cutting out some of the liner to make wheels work. Odds are you may have to do some handy work as they probably wont be a perfect fit.
If I remember right the rear offset for the wheel setup like that is +35 mm and it is 9.5 wide. Even if the rear was the 49 mm like the front 9.5 is still too wide to fit in the rear.
from the looks of the picture the lip of the wheel is not any different so that entire inch is probably all on the inside which would be much more difficult to deal with since rolling the fenders wouldn't help anything.
but that's just my best guess from looking at the picture.
I like the design on them. I'd take them over the Sentas.
07+XK front wheels fit.
Edit: 04+XJ wheels also fit. Just in case if you see some XJ wheels you like. You'll know what fits.
