Will these fit?
No, they will not fit a mark viii unless you have done the hub swap to mustang bolt pattern. Those wheels are 5x114.3 or 5.4.5. You need 5\108 or 5\4.25.
Mark VIIIs have a 39mm offset, those are an inch wider than the stock 16x7s and have a 45mm offset. So... maybe, maybe not :D
ok thst what I thought, I might get those or some grey painted 18x9 FR500 because there cheaper.
New is almost always a better option IMO. You never know what the hell you are going to get in a used wheel. Its riskey enough buying stuff like that from fellow forum members.
Brad
