Will these fit?
buddyleee5
Ls ville
Brand New Set of Four TIS Wheels!
Manufacturer: Twenty Inches Strong
Style: 07
Finish: Chrome Plated
Bolt Pattern: 5x4.25/4.5
Offset: +30
Will the +30 offset work with the 7.5" wide rim? And just confirming that the 5x4.25 is the correct bolt pattern
LS is a 5x108 pattern which is about 4.25 inches so you should be safe there.
30mm offset will stick out past the fenders. you need a 42mm or higher offset to be safe. Stock wheel is 7.5" with a 60mm offset
what about an 8.5" wheel with a +38 offset. I can't seem to find any that are a +42 offset. If anyone can find them the rims i am looking for are tis 07's
