who runs an auburn pro diff
Gilby959798
Diamond in the Rough
this isnt about the mark viii but i know some of you guys run the auburn pro differential. i know the backlash and preload was set correctly but when i really get on it i have a noise.. like a squelch.. kinda hard to describe but i was wondering if you guys experienced this or not... thanks
did you do the gear run out on it. it is important to have the correct gear pattern on a run out. it should be a cigar type pattern on the ring gear in the center of the gear. if it is not in the center of the gear or if you skipped this step your in real trouble.
yeah the pattern looked good according the the guy that helped me install it... he sets up his rear ends for his drag car all the time. its not a gear noise and it doesnt happen all the time. it seems like the clutches need broke in on the unit is what it sounds like to me
try doing the multiple fugure 8 s and see what happens. maybe they just need to be broke in. under hard accel they shouldnt squeel though. the clutches should be fully locked.
yeah im going to try that tonight... its hard to try this stuff when the car is not where i am at... errr ill let you guys know tonight...
