Ok do a search you'll find loads of info that you can piece together that I will never have the time to explain in one post. This is probably the most covered topic.
Ill tell you I run 19x8.5 with a +38 offset and it is perfect. No gap between wheel and fender, no poke and so forth. I would definitely start going up in offset if you go wider.
