wheel spacers
stallone 81
New Jersey
got a good deal on wheel spacers 25mm is that too much like will my wheel go passed the fender ?
you'll be at 35mm with that. You might be ok if you dont go over bumps and dont lower it. But if you lower it you will prob need to get the fender rolled.
im lowered now lol =p with the stockers with that offset you think id have to roll the fenders
how much do they go for (spacers)
i want some cuz i hate the way the back wheels look when im behind my car, or any other ls for that matter
Should be ok. Minor rubbing in the back probably but u can fix that by cuttin out some the fender liner. Are they hub centric?
they run like a hundred a pair i found a guy on craiglist selling a pair for 35 bucks lol
what do you mean by hub centric lol i know they look like this
http://cgi.ebay.com/ebaymotors/H-R-...ptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
hub centric means that the center of the spacer is the same size as the LS' center hub and then it has a centering hub coming out same size for the LS wheel.
Yes, like the ones in the picture, make sure they are correct size or you gonna have shaking problems. Also the spacers for the LS are basically adapters that go from 5x108 to 5x108. They have studs coming out of them. If you buy the ones with just holes in them your car's lugs are gonna be short.
