Wheel question
They'll bolt on, but the +35mm offset is a little on the low side which'll make 'em stick out of the wheel wells a bit.
+38 works just the same!
Many of the people that actually have experience with this offset agree.
If you ever notice how far the wheel is set back stock you know you have room for play.
You can use a 38mm offset with the correct size tire. I had +38 wheels with a 245/45-18 tire and rubbed like crazy out back. 245/40-18 would have worked better.
I'll take my +46 offset 19s. :)
38+ offset 245/40/18 fit just fine but 42 or 45 offset would look just as good. I have a 8.5" wheel and it doesnt stick out.
