wheel alignment?
JattGary
Chicago
Can someone tell me if this is done right, my car is lowered with Eibach Springs.
It will never be exactly like the factory setting, all they can do is get very close. One more item, but you might want to get another aligment in about 2000 miles or so. The springs will settle in by then.
Looks good, up to 1 degree negative camber is good for street daily use and tire wear. The rear camber is not adjustible I believe so that is what it is, no choice there without modifying for adjustments, 2 derees more agressive for handling, a little more tire wear on the edges
Maybe not exactly, but certainly within all of the factory ranges...
