What Offset
mafioso
Bedford
Im curious to know what the widest wheel I can run in the back, with the lowest offset so that I can still lay pinch weld taking the amount of camber into consideration is? I Aqquried a set of 20x8.5 in a +15 offest. but they are 5x4.5 so they wont fit yet. whats the best way to measure it out.
right now Im having a slight rubbing issue aired out in the rear with the stock wheels and 245-60-16's its rubbing the wheel wells in the sides and not on top as one might expect.
I was given some 20"s in 5x4.5" which works out perfect since I need to swap out the front brakes to an SN-95 hubs. but Im looking to find out how much of a problem I will have with the offset.
