What looks right on this PS line?
Icarus
Ontario, Canada
I picked up a new pressure line and the fitting that goes between it and the rack today because mine started leaking. :(
The L-shaped line I got from Ford had a fitting in it (circled in red) that I was confused about and wanted to make sure I'm doing the right thing here...
The ps line had the end on it (green part) that in no way fit with the fitting, so I unscrewed the one from the L-line and put the ps line fitting in there.
Looks right, correct?
I just wanted to make sure as it's -10* here and I only wanted to be outside for a short time, and not have a leaker when I'm done ;)
Thanks
you are correct, sorta, in fords eyes you can remove the old nut off of your existing line and install the new one. that way you replace the seal inside of the nut too. BUT ive been a ford tech for 10 years and ive NEVER seen anyone get one off. just throw it in your spare parts bin
I figured it was someting along those lines, I just didn't want to hook it up and have a guyser when I started it!
Thanks chicken :)
