What kind of wheels?
kaball
Daytona Beach
Hey guys I am a tad bit new here and would like your opinion on a new set of wheels. I have a set of 16" American Racing and would like to upgrade to either 17's or 18's. I have seen the calculations and the difference in speeds. I was debating at the moment between the new Enkei Ammodo's (they make one in 5x108) or the Enkei PF01's.
On another note if I did go with the PF01's are wobble bolts a good idea or should I stick with 5x108s?
I don't know what a wobble bolt is but just from the sound of it I wouldn't use it.
Wobble and wheel don't go together.
lol I know how you feel. I tried posting a link to it but it was waiting to get approved. It is basically a bolt that allows you to go one size bigger on bolt patterns. So for us it would allow us to go from 5x108 to 5x110. Its kind of like a washer on a longer bolt. My friend told me about them...then again he is a VW owner.
Wobble bolts are sketchy. If you want a different bolt pattern at a minimum get properly made adapters
ok so nix the wobble bolt idea and possibly the spacer/adapter. Any ideas on a nice set of wheels?
Kaball it all depends on what size/style you want. There are many options....Anything you want in particular
I would like something lighter. I have a midnight blue 02 V8, so no chrome or colors, Silver looks best but I am open for suggestions. Like I said before I have 16s on there now with a LOT of sidewall lol.
Jaguar has some nice OEM silver finish 18 and 19" options which are popular with members on here. I'd start there and see if you like any of those.
C/P from - http://www.ecstuning.com/Search/Wobble_Bolts/ES2130074/
Wobble Bolt 14x1.5x27 - Priced Each
Conical seat wobble bolt to fit 5x114.3 bolt pattern wheels to your 5x112 vehicle
Don’t limit yourself to your factory bolt pattern. Pick up these new Wobble Bolts from ECS Tuning and expand your wheel possibilities. These bolts feature a floating conical seat collar that allows movement up to 3mm of a wheel's PDC, which in turn, will allow you to run a 5x114.3 bolt pattern on your 5x112 pattern. On top of that, they are zinc coated to ensure long life. These bolts will fit most aftermarket wheels.
Specs:
14mm diameter
1.5mm thread pitch
27mm length
*Priced Each*
