vikingdiesel
I have an 02 LS V8 100k, I know its the vavle cover gasket that needs to be replaced, but the car runs and drives and idles fine, NO CHECK ENGINE light or anything, I only ended up changing one plug since the further I kept going, more of the coils had oil in them. I decided to just leave it the way it is then, with the plugs in them, NOT replacing the plugs, since then oil would get in the holes, this way if I just let it be, it will continue to run and drive fine or should I just replace the plugs... thoughts??? However, after replacing the first plug and when I started the car, there was a slight poof of white smoke form the engine bay, but it instantly went away. Was that prob just spark contact with the oil....?
