Water rear reflector
antonio fuller
Decatur, Georgia, United States
Hey it seems I have a broke seal on my back reflector causing water to get inside and make it just look bad its the one that's part of the trunk hood so I don't think its a hard fix but I never did it before so wanted to get info on what most likely needs to be replaced and how
I gave in and just drilled some tiny drain holes at the bottom edge (facing down) of the one on my 04 that was collecting water. That was a few years ago. So far it is fine.
I ran a bead of clear silicone bath sealant between the rubber gasket and the light.
First, take the light off and dry and clean it completely. Then do the sealing and re-install.
That assumes you don't find a crack in the light.
Shouldn't your warranty cover this? Or is it just a powertrain warranty?
