vibrating car 03 Lincoln Ls V8
em3g
San Diego
When driving on the highway and city streets car runs perfectly fine but when stopped at a redlight or stop sign car begins to vibrate...it's not an intense vibration but just enough to be an annoyance also when placed in park vibration stops...can somebody pls shed some light on the situation PLEASE thnks:)
your engine is probably not running right. this is the vibration you feel while not moving.
it could be a lot of things,do you have any codes?
my ls started vibrating when the oil was a bit low or old, or maybe you have a small vacuum leak, or a plug or bad coil. could be a lot of things! but my vibration went away with every oil change. start by checking the basics like air filter, tps and maf cleaning, fuel filter, plugs, etc.
