Hello all !
Ok well back at 117000 I replaced the tensioner and well then the chain snapped. I replaced two exhaust valves (fun
) and now my black beauty has 122000 and still running strong, must be a miracle!!
Any how, as I removed everything I removed the power steering pulley prior to removing the pump thought it was easier to remove the 4 bolts without the pulley in the way.
Problem is when installing the pulley I snapped out the long install bolt and it ended up not being all the way in which is why it squeaks like crazy on cold mornings for about 45mins which here in St. Louis will be for the next few months.
Any ideas on another way of installing that pulley further in? I can't bolt anything into the shaft hole since it has a piece of bolt stuck....
Easier to just replace the pump and re-use the pulley rather than attempting to bench press the pulley on?
Thanks !
Thanks !
