Pete 2004 LS V-6
My 2004 LS V-6 will skip at times when under any load. This car has 41,000 miles on it. We just don't drive much. It will set two or three months without being run. We took a 400 mile trip this weekend and as I was going over it for the trip (had not been run in three months) I found a squirrel nest on the intake, no damage at all, cleaned it up and good to go. Car was in the carport covered. I have been going under the assumption that the ****ty ethanol gas was causing moisture in the tank (I live on a large lake) and that was my skip, it was not giving a code. This has been going on for a while, but this weekend it finally set a code, can't remember the numbers, gave my printout to my mechanic. They were excessive skip cylinder #2 and one was something about (I think, sorry) the ECM not communicating with the transmission and another about some communication problem. Anyway the guy that will work on it if need be said he would have to check the vin #, he said that he had a 3.0 V-6 in last week that had a bad coil, the bad coil (he said it would be swollen) would damage the ECM, he said there was a service bulletin out on the problem. He said that he would have to change all the coils and the ECM and plugs, I would think the plugs would be well while I'm here we should change them, not a problem for me!! Does anyone know anything about this? Thanks in advance for any info.
