Upper control arm bushing
MarkOfDeath
IL
I think mine are bad, if you you push the tire hard it has alittle play in it and I looked around and after check the lugs I believe it is the upper control arm bushing, are these know for going bad and how hard is it to fix.
I know of no place that has replacement bushings for the upper control arms. I think you have to buy the whole upper control arm to replace anything.
then my friend I simply ignore it, job well done I need a beer
