Unplugging the antenna
in the trunk, you can pull back the carpet and unplug the power from the motor. its right under the antenna.
I was going to pull it at first but was not sure if it was screwed in.
I can't lean in all that far to look at it good enough.I can reach it though.
Pretty sure he is in a wheelchair. Do you have an aftermarket stereo? If so you can unhook the wire behind the dash, but then you can only listen to Cds or an Ipod.
marks and conti are gangster cars they will hold three bodies and plenty of ammo.plus a shovel
But not a wheelchair. :p Damn thing hangs out like a lawnmower,and with the wheels off.
No just the stock stereo but with the antenna problem reception isn't very good at all.I don't care about a radio right now anyway.
