uncommon problem have you had it?
tripolincoln
paso robles
so the fuse in the #5 spot in the fuse box in the inside passenger side keeps blowing if controls my advance traction "light and message on", heated seats and not 100% sure what else but when i put a higher fuse in just to check it everything work but the traction control light stayed blinking
now its been awhile since it happend so dont remember when exactly it happen but it was around the time my buddy and i put in my aftermarket cd play, and dont know if its somthing we did or was it somthing that just happend
help me out i need some ideas on what i can check or do thanks guys
Do you know what that fuse is for? I'm too lazy to look at the moment.. What an a$$ I know..
Did you even read his post... jeeze ;)
i cant find my owners manual right now but the things i mentioned are some of them like the heated seat the advance traction
What year? In the tech articles theres owners manual PDF's
In my PDF manual:
T/A Switch, O/D Cancel Switch, Autolamp
Sensor, Heated Seat Modules
If you don't turn the heated seats on does it still pop? I'm thinking that the seats may have not enough resistance which is causing excess current to flow.. I think that is highly unlikely but I don't see anything else.. Maybe Joe will chime in..
Maybe the modules for the seats are bad because they usually catch when the element in the seat is open and kick the circuit off (you push the light, it comes on and goes off shortly after)..
well if i try putting in a fuse as soon as i turn the key it blows it only stayed on the one time i put the higher fuse in and as i remember that i had the heated seats on when it blew the higher fuse, but when i had the higher fuse in the traction control went from staying on to flashing and stayed flashing until it blew so if it is soething to do with the heated seat then why would that light go from on to flashing?
Good point.. I'm lost..
can't do hw if your on here :p
Not too easily.. lol
