Turning off running day lights
Uncle Vinnie
Canada
Is there a way to keep only the fog lights on, while driving, vs having the daylight, and fog lights all the time.
Thanks
you can turn of the running day lamps if you have a xcal but you will then haveto to turn your fogs on manually when you drive.
DRL is a mandatory feature of the Canadian PCM programming, only a dealer can change, which won’t happen in Canada.
