TSBs
joegr
Gulfport
I have temporary access to the Ford TSBs. If you have a real need for one of them, let me know. If I'm not too busy, I might pull it up for you.
2000 TSBs
Technical Service Bulletins
- US (English)
The Technical Service Bulletins (TSB's) listed here may NOT apply to the vehicle you are working on. You MUST run OASIS with a specific VIN and Symptom Code to determine if it applies. If OASIS does not return the TSB, then it does NOT apply.
08-16-5
3.9L ACCESSORY DRIVE BELT SNAP NOISE IN FREEZING TEMPERATURES
07-5-8
BATTERY SERVICE - OPERATION OF BATTERY EYE - CHARGING SERVICE TIPS
07-4-3
LEATHER-WRAPPED STEERING WHEEL - LEATHER COMING LOOSE
07-1-7
MERCON® ATF REPLACED BY MERCON® V AS A SERVICE FLUID FOR SOME POWER STEERING SYSTEMS
06-25-15
ALUMINUM BODY PANELS - CORROSION - SERVICE TIP
06-21-19
HEATER CORE LEAKAGE AND ELECTROLYSIS (INFORMATION ONLY)
06-18-16
IDENTIFYING THE CORRECT REPLACEMENT HEAD GASKET FOR CERTAIN REMANUFACTURED ENGINES - SERVICE TIP
06-15-8
KEYPAD DIAGNOSTICS - DEALER INSTALLED ACCESSORY
06-8-3
SPEED CONTROL DIAGNOSTIC TIPS - PCM
05-22-9
BATTERY DRAIN DIAGNOSIS - SERVICE TIPS
05-22-8
WDS COP KIT DIAGNOSTIC TIPS - COIL ON PLUG (COP) IGNITION SYSTEMS - ENGINE MISFIRE OR ROUGH RUNNING
05-18-7
WIRING - SOLDERING AND CRIMPING REPAIRS - SERVICE TIPS
05-16-11
SAFETY BELT RETRACTION SPEED
05-16-2
WATER/MOISTURE IN COP WELLS - DTC P0301-P0308 - 3.9L ENGINE - VEHICLES BUILT THROUGH 5/1/2004
05-3-10
SAFETY BELT WEB STOP BUTTON SERVICE
04-24-5
REAR WINDOW DEFROSTER GRID/INTEGRAL ANTENNA DIAGNOSIS AND REPAIR - TERMINAL TAB REPAIR
04-17-4
MALFUNCTION INDICATOR LAMP (MIL) ILLUMINATED - SYSTEM LEAN DIAGNOSTIC TROUBLE CODES (DTC'S) - SERVICE TIPS
04-10-2
BODY - TRIM EXTERIOR - LOOSE REAR LICENSE PLATE ATTACHMENT
04-6-3
BODY - POWER WINDOW - REAR POWER WINDOW INOPERATIVE - VEHICLES BUILT THROUGH 1/22/2002 - REVISED SERVICE PROCEDURE
ELECTRICAL - POWER WINDOW - REAR POWER WINDOW INOPERATIVE - VEHICLES BUILT THROUGH 1/22/2002 - REVISED SERVICE PROCEDURE
03-23-2
BODY - MIRROR - EXTERIOR MIRROR GLASS AND MOTOR REPLACEMENT - SERVICE TIPS
03-18-1
ELECTRICAL - REMOTE KEYLESS ENTRY (RKE) - SERVICE TIPS
03-16-2
BODY - HEADLAMP - MOISTURE IN HEADLAMP ASSEMBLY
ELECTRICAL - HEADLAMP - MOISTURE IN HEADLAMP ASSEMBLY
03-14-8
TRANSMISSION - NEW TRANSMISSION COOLER FLUSHER - SERVICE TIPS
03-7-3
DRIVEABILITY - ENGINE FLOODING, EXTENDED CRANK TIME OR HARD STARTING - COLD ENGINE WITH AMBIENT TEMPERATURES 30-40 F (-1-5 C) WITH GREATER THAN 75% HUMIDITY ONLY
03-3-5
DRIVEABILITY - IDLE AIR CONTROL (IAC) VALVE DIAGNOSTIC SERVICE TIPS
03-3-4
CLIMATE CONTROL - LACK OF COOLING FROM DRIVER AND/OR PASSENGER SIDE VENTS - VEHICLES EQUIPPED WITH DUAL AUTOMATIC TEMPERATURE CONTROL (DATC) ONLY
03-2-3
BRAKES - ABS/ATS (ANTILOCK BRAKING SYSTEM/ADVANCE TRAC SYSTEM) DTCS C1288/C1289 DIAGNOSIS - SERVICE TIPS
02-25-2
ELECTRICAL - CDX6 RADIO DAMAGED DURING SERVICE SHIPPING - CORRECT SHIPMENT PROCEDURES FOR CDX6 RADIO - SERVICE TIPS
02-21-15
CLIMATE CONTROL - MUSTY ODOR FROM CLIMATE CONTROL
02-21-13
ENGINE - STRAIGHTEDGE PROCEDURE FOR CHECKING CYLINDER HEAD AND BLOCK FLATNESS
02-17-6
LAMP - BRAKE - INADVERTENT DISABLING OF BRAKE SHIFT INTERLOCK
02-13-7
ELECTRICAL - SIDE AIR BAG DIAGNOSTIC CODES (DTC) B1994 AND/OR B1998 - VEHICLES BUILT BEFORE 2/18/02 ONLY
02-12-2
ELECTRICAL - VEHICLE SYSTEMS GROUND LOCATIONS - INTERMITTENT FAULT DIAGNOSTIC TIPS
02-11-4
ENGINE - NEW GASKET REMOVER/CLEANER AND SERVICE TIPS FOR ALUMINUM HEADS AND BLOCKS
02-6-6
TRANSMISSION - 5R55N - FLUID LEAK AT TRANSMISSION FLUID PAN DRAIN PLUG
02-4-4
ELECTRICAL - RAIN SENSE WIPER SYSTEM INFORMATION - DIAGNOSTIC AID - SERVICE TIPS
02-1-9
ENGINE - ENGINE OIL - RECOMMENDED APPLICATIONS FOR SAE 5W-20 AND SAE 5W-30 MOTOR OILS - GASOLINE AND FLEXIBLE FUEL VEHICLES ONLY
01-23-6
ENGINE COOLANT - PROPYLENE GLYCOL - FORD MOTOR COMPANY POSITION ON ENGINE COOLANTS MADE FROM PROPYLENE GLYCOL
ENGINE COOLANT - PROPYLENE GLYCOL-BASED - FORD MOTOR COMPANY POSITION ON PROPYLENE GLYCOL-BASED ENGINE COOLANTS
01-21-7
NOISE - "MOANING/DRONING" DURING LIGHT ACCELERATION AT HIGHWAY SPEEDS
01-16-4
DRIVEABILITY - NO START - INTERMITTENT CRANK NO START - THEFT WARNING LAMP FLASHING - VEHICLES PRODUCED BEFORE 6/15/2001
ELECTRICAL - THEFT WARNING LAMP FLASHING - INTERMITTENT CRANK NO START - VEHICLES PRODUCED BEFORE 6/15/2001
01-15-1
STEERING - STEERING WHEEL "NIBBLE" - SPEEDS ABOVE 100 KM/H (60 MPH)
NOISE - LOW FREQUENCY "HUM" AND/OR "BOOM" - SPEEDS ABOVE 100 KM/H (60 MPH)
VIBRATION - FELT IN SEAT, STEERING WHEEL AND/OR FLOORPAN - SPEEDS ABOVE 100 KM/H (60 MPH)
01-14-5
TRANSMISSION - 5R55N - DELAYED REVERSE OR DRIVE ENGAGEMENTS - HARSH UPSHIFTS OR DOWNSHIFTS - ERRATIC UPSHIFTS - DELAYED DOWNSHIFTS NEAR 20 MPH - VEHICLES BUILT BEFORE 10/17/2000
01-10-12
WIRING - WIRE HARNESS TERMINAL REPAIR KIT AND WIRE SPLICE PROCEDURE
01-9-7
DRIVEABILITY - HO2S (HEATED OXYGEN SENSOR), CATALYST, AND FUEL SYSTEM MONITORS - SERVICE TIPS - OBD II VEHICLES ONLY
01-6-2
PASSIVE ANTI THEFT SYSTEM (PATS) - DIAGNOSTIC SERVICE TIPS
01-1-8
TRIM - SEATS - LACK OF COMFORT FROM FRONT SEATS
01-1-6
DIAGNOSTIC TROUBLE CODES (DTCS) - P0350-P0360 COIL DTCS STORED IN MEMORY - ROUGH IDLE - MALFUNCTION INDICATOR LAMP (MIL) ILLUMINATED - COIL ON PLUG APPLICATIONS ONLY
MALFUNCTION INDICATOR LAMP (MIL) ILLUMINATED - ROUGH IDLE - DIAGNOSTIC TROUBLE CODES (DTCS) P0350-P0360 COIL DTCS STORED IN MEMORY - COIL ON PLUG APPLICATIONS ONLY
ROUGH IDLE - MALFUNCTION INDICATOR LAMP (MIL) ILLUMINATED - DIAGNOSTIC TROUBLE CODES (DTCS) P0350-P0360 COIL DTCS STORED IN MEMORY
LAMP - MALFUNCTION INDICATOR LAMP (MIL) ILLUMINATED - ROUGH IDLE - DIAGNOSTIC TROUBLE CODES (DTCS) P0350-P0360 COIL DTCS STORED IN MEMORY - COIL ON PLUG APPLICATIONS ONLY
00-23-10
TRANSMISSION - FLUID IN-LINE FILTER KIT - REPEAT REPAIRS OF TRANSMISSION - SERVICE TIPS
00-21-3
CLIMATE CONTROL - EATC - BLOWER MOTOR CONTROL SERVICE TIPS
00-18-5
STALL - VEHICLES BUILT 3/15/1999 THROUGH 11/11/1999 EQUIPPED WITH 5R55N TRANSMISSION
TRANSMISSION - 5R55N - NO ENGAGEMENT - VEHICLES BUILT 3/15/1999 THROUGH 11/11/1999
00-17-3
LAMP - LICENSE PLATE - LOOSE AND/OR FALLING OUT OF POSITION - VEHICLES BUILT FROM 3/1/1999 THROUGH 5/8/2000
00-12-1
NOISE - HIGH PITCHED GEAR "WHINE" HEARD WHILE DRIVING AND/OR COASTING AT LOW SPEEDS IN FIRST OR SECOND GEAR - VEHICLES EQUIPPED WITH 5R55N TRANSMISSION AND BUILT 3/15/1999 THROUGH 4/17/2000
TRANSMISSION - 5R55N - HIGH PITCHED GEAR "WHINE" HEARD WHILE DRIVING AND/OR COASTING AT LOW SPEEDS IN FIRST OR SECOND GEAR - VEHICLES BUILT 3/15/1999 THROUGH 4/17/2000
00-11-2
AIR CONDITIONING - BLOWER MOTOR STAYS ON HIGH - EATC VEHICLES ONLY
AIR CONDITIONING - TEMPERATURE DOES NOT MAINTAIN SETPOINT - EATC VEHICLES ONLY
00-8-8
AIR CONDITIONING - DATC OPERATION - SERVICE TIP
00-5-8
REMOVAL OF FRONT WHEEL ANTI-LOCK BRAKE SYSTEM WHEEL SPEED SENSOR - SERVICE TIP
00-4-3
POWER WINDOW - FRONT - "SQUEAKING/CREAKING" NOISE HEARD WHEN POWER WINDOW IS OPERATED - VEHICLES BUILT FROM 3/1/1999 THROUGH 11/1/1999
NOISE - "SQUEAKING/CREAKING" HEARD WHEN POWER WINDOW IS OPERATED - VEHICLES BUILT FROM 3/1/1999 THROUGH 11/1/1999
00-3-2
AIR CONDITIONING - INACCURATE AMBIENT TEMPERATURE DISPLAYED - EATC EQUIPPED VEHICLES - CONTINENTAL AND LS BUILT THROUGH 10/15/1999, ALL OTHERS BUILT THROUGH 8/31/1999
99-26-8
BRAKES - "POPPING" NOISE FROM THE BRAKE PEDAL AREA, WITH POSSIBLY PEDAL MOVEMENT - VEHICLES WITH ADVANCE TRAC VEHICLE STABILITY CONTROL SYSTEM BUILT THROUGH 10/11/1999
NOISE - "POPPING" FROM THE BRAKE PEDAL AREA - VEHICLES WITH ADVANCE TRAC VEHICLE STABILITY CONTROL SYSTEM BUILT THROUGH 10/11/1999
99-26-1
HESITATION/STUMBLE - DURING ACCELERATION FROM LOW SPEED - VEHICLES BUILT FROM 3/15/1999 THROUGH 12/1/1999
LONG CRANK - VEHICLES BUILT FROM 3/15/1999 THROUGH 12/1/1999
MALFUNCTION INDICATOR LAMP ILLUMINATION - ENGINE MISFIRE - VEHICLES BUILT FROM 3/15/1999 THROUGH 12/1/1999
SURGING - DURING LIGHT LOAD, STEADY SPEED DRIVING - VEHICLES BUILT FROM 3/15/1999 THROUGH 12/1/1999
TRANSMISSION - 5R55N - HARSH ENGAGEMENT - VEHICLES BUILT FROM 3/15/1999 THROUGH 12/1/1999
TRANSMISSION - 5R55N - HARSH OR DELAYED SHIFTS - VEHICLES BUILT FROM 3/15/1999 THROUGH 12/1/1999
99-23-4
MALFUNCTION INDICATOR LAMP (MIL) - DIAGNOSTIC TROUBLE CODES (DTCS) P0442 AND P0455 - NO DRIVEABILITY CONCERNS
99-23-3
BRAKES - LONGER THAN EXPECTED PEDAL TRAVEL WITHOUT ADDITIONAL PEDAL EFFORT - VEHICLES BUILT FROM 3/1/1999 THROUGH 8/9/1999 AND WITH V-6 ENGINE
BRAKES - REDUCED POWER BRAKE ASSIST - DURING RAPID, REPEATED BRAKE APPLICATIONS - HIGH ALTITUDE OPERATION - VEHICLES BUILT FROM 3/1/1999 THROUGH 8/9/1999 AND WITH V-6 ENGINE
99-23-1
TRANSMISSION - 5R55N - SHIFT ADAPTIVE ELECTRONIC PRESSURE CONTROL STRATEGY - SERVICE TIP
99-11-1
NOISE - TSB SPECIAL FOR NOISE/VIBRATION/HARSHNESS
VIBRATION - TSB SPECIAL FOR NOISE/VIBRATION/HARSHNESS
99-8-13
TRANSMISSION - 5R55N - DESCRIPTION OF FEATURES AND MAJOR COMPONENTS
2001 TSBs
08-16-5
3.9l accessory drive belt snap noise in freezing temperatures
07-5-8
battery service - operation of battery eye - charging service tips
07-4-3
leather-wrapped steering wheel - leather coming loose
07-1-7
mercon® atf replaced by mercon® v as a service fluid for some power steering systems
06-25-15
aluminum body panels - corrosion - service tip
06-21-19
heater core leakage and electrolysis (information only)
06-18-16
identifying the correct replacement head gasket for certain remanufactured engines - service tip
06-15-8
keypad diagnostics - dealer installed accessory
06-8-3
speed control diagnostic tips - pcm
05-22-9
battery drain diagnosis - service tips
05-22-8
wds cop kit diagnostic tips - coil on plug (cop) ignition systems - engine misfire or rough running
05-18-7
wiring - soldering and crimping repairs - service tips
05-16-11
safety belt retraction speed
05-16-2
water/moisture in cop wells - dtc p0301-p0308 - 3.9l engine - vehicles built through 5/1/2004
05-3-10
safety belt web stop button service
04-24-5
rear window defroster grid/integral antenna diagnosis and repair - terminal tab repair
04-17-4
malfunction indicator lamp (mil) illuminated - system lean diagnostic trouble codes (dtc's) - service tips
04-10-2
body - trim exterior - loose rear license plate attachment
04-6-3
body - power window - rear power window inoperative - vehicles built through 1/22/2002 - revised service procedure
electrical - power window - rear power window inoperative - vehicles built through 1/22/2002 - revised service procedure
03-23-2
body - mirror - exterior mirror glass and motor replacement - service tips
03-20-3
driveability - malfunction indicator lamp (mil) illuminated with dtc's p0442, p0455, p0456, p0457, p1442 or check fuel cap lamp illuminated with dtc p0457
03-18-1
electrical - remote keyless entry (rke) - service tips
03-16-2
body - headlamp - moisture in headlamp assembly
electrical - headlamp - moisture in headlamp assembly
03-14-8
transmission - new transmission cooler flusher - service tips
03-7-3
driveability - engine flooding, extended crank time or hard starting - cold engine with ambient temperatures 30-40 f (-1-5 c) with greater than 75% humidity only
03-3-5
driveability - idle air control (iac) valve diagnostic service tips
03-3-4
climate control - lack of cooling from driver and/or passenger side vents - vehicles equipped with dual automatic temperature control (datc) only
03-2-3
brakes - abs/ats (antilock braking system/advance trac system) dtcs c1288/c1289 diagnosis - service tips
02-25-2
electrical - cdx6 radio damaged during service shipping - correct shipment procedures for cdx6 radio - service tips
02-21-15
climate control - musty odor from climate control
02-21-13
engine - straightedge procedure for checking cylinder head and block flatness
02-21-3
steering - steering column pop/click noise repair procedure
02-17-6
lamp - brake - inadvertent disabling of brake shift interlock
02-13-7
electrical - side air bag diagnostic codes (dtc) b1994 and/or b1998 - vehicles built before 2/18/02 only
02-12-2
electrical - vehicle systems ground locations - intermittent fault diagnostic tips
02-11-4
engine - new gasket remover/cleaner and service tips for aluminum heads and blocks
02-6-6
transmission - 5r55n - fluid leak at transmission fluid pan drain plug
02-4-4
electrical - rain sense wiper system information - diagnostic aid - service tips
02-1-9
engine - engine oil - recommended applications for sae 5w-20 and sae 5w-30 motor oils - gasoline and flexible fuel vehicles only
01-23-6
engine coolant - propylene glycol - ford motor company position on engine coolants made from propylene glycol
engine coolant - propylene glycol-based - ford motor company position on propylene glycol-based engine coolants
01-21-11
driveability - diagnostic trouble codes (dtc) p1285 and/or p1299 - engine overheat condition
electrical - lamp - malfunction indicator lamp (mil) illuminated - diagnostic trouble codes (dtc) p1285 and/or p1299 - engine overheat condition
cooling system - engine overheat
engine - engine overheat
01-21-7
noise - "moaning/droning" during light acceleration at highway speeds
01-16-4
driveability - no start - intermittent crank no start - theft warning lamp flashing - vehicles produced before 6/15/2001
electrical - theft warning lamp flashing - intermittent crank no start - vehicles produced before 6/15/2001
01-15-1
steering - steering wheel "nibble" - speeds above 100 km/h (60 mph)
noise - low frequency "hum" and/or "boom" - speeds above 100 km/h (60 mph)
vibration - felt in seat, steering wheel and/or floorpan - speeds above 100 km/h (60 mph)
01-14-5
transmission - 5r55n - delayed reverse or drive engagements - harsh upshifts or downshifts - erratic upshifts - delayed downshifts near 20 mph - vehicles built before 10/17/2000
01-10-12
wiring - wire harness terminal repair kit and wire splice procedure
01-9-7
driveability - ho2s (heated oxygen sensor), catalyst, and fuel system monitors - service tips - obd ii vehicles only
01-6-2
passive anti theft system (pats) - diagnostic service tips
01-3-3
driveability - diagnostic trouble code (dtc) p1572 stored in memory - malfunction indicator lamp (mil) illuminated - vehicles built prior to 2/28/2001
electrical - lamp - malfunction indicator lamp (mil) illuminated - diagnostic trouble code (dtc) p1572 stored in memory - vehicles built prior to 2/28/2001
01-1-8
trim - seats - lack of comfort from front seats
00-23-10
transmission - fluid in-line filter kit - repeat repairs of transmission - service tips
00-21-3
climate control - eatc - blower motor control service tips
2002 TSBs
- US (English)
09-12-12
5R55S/5R55N/5R55W TRANSMISSIONS - SHIFT CONCERNS, LOSS OF 2ND, 3RD AND 5TH GEAR, INCORRECT RATIO DTC'S - PROCEDURE TO INSPECT AND REPAIR SERVO PIN BORE WEAR
08-16-5
07-5-8
07-4-3
07-1-7
06-25-15
06-21-19
06-18-16
06-15-8
06-8-3
05-22-9
05-22-8
05-18-7
05-16-11
05-16-2
05-3-10
04-24-5
04-17-4
04-10-2
04-6-3
03-23-2
03-20-3
DRIVEABILITY - MALFUNCTION INDICATOR LAMP (MIL) ILLUMINATED WITH DTC'S P0442, P0455, P0456, P0457, P1442 OR CHECK FUEL CAP LAMP ILLUMINATED WITH DTC P0457
03-18-1
03-16-2
03-14-8
03-10-1
PAINT - PLASTIC BUMPER/FASCIA PARTS - PREPARATION PROCEDURES - SERVICE TIPS
03-8-3
ENGINE - ENGINE OIL LEVEL INDICATOR MARKINGS - REPORTS OF LOW OIL LEVELS
03-7-3
03-3-7
BODY - PAINT - NO CLEARCOAT BLENDING - COLLISION MANUAL CHANGE
03-3-5
03-3-4
03-2-3
03-1-7
DRIVEABILITY - MIL (MALFUNCTION INDICATOR LIGHT) WITH DTC P0460 (FUEL LEVEL SENSOR CIRCUIT ERROR) - SERVICE TIPS
ELECTRICAL - MIL (MALFUNCTION INDICATOR LIGHT) WITH DTC P0460 (FUEL LEVEL SENSOR CIRCUIT ERROR) - SERVICE TIPS
02-25-2
02-23-7
COOLING SYSTEM - MOTORCRAFT PREMIUM GOLD ENGINE COOLANT - SERVICE TIPS
02-21-15
02-21-13
02-21-3
STEERING - STEERING COLUMN POP/CLICK NOISE REPAIR PROCEDURE
02-20-3
TRANSMISSION - 5R55N, 5R55S, 5R55W - NEW ROTUNDA TOOL FOR CHECKING FLUID LEVEL AND FILLING TRANSMISSIONS
02-17-6
02-16-3
PAINT - NEW POLISHING PRODUCTS - SERVICE PROCEDURES
02-13-7
02-12-2
02-11-4
02-6-6
02-5-6
SHEET METAL - PRIMED SERVICE PARTS - PREP PROCEDURE AND MSDS INFORMATION
02-4-4
02-1-9
01-23-6
01-21-11
DRIVEABILITY - DIAGNOSTIC TROUBLE CODES (DTC) P1285 AND/OR P1299 - ENGINE OVERHEAT CONDITION
ELECTRICAL - LAMP - MALFUNCTION INDICATOR LAMP (MIL) ILLUMINATED - DIAGNOSTIC TROUBLE CODES (DTC) P1285 AND/OR P1299 - ENGINE OVERHEAT CONDITION
COOLING SYSTEM - ENGINE OVERHEAT
ENGINE - ENGINE OVERHEAT
01-21-7
01-15-1
01-10-12
2003 TSBs
- US (English)
09-12-12
08-16-5
08-12-4
3.0L - VACUUM LEAKAGE NOISE AND MIL ON WITH LEAN CODES
07-12-3
RCM FAULT REPORTING USING DTCS AND BIT-MAPPED PARAMETER IDENTIFIERS (PIDS) - SERVICE TIPS
07-5-8
07-4-3
07-1-7
06-25-15
06-25-13
PARKING AID SYSTEM INOPERATIVE - DTC C1983
06-21-19
06-18-16
06-15-8
06-5-16
STEERING GEAR SQUEAK WHEN TURNING THE STEERING WHEEL DURING LOW SPEED PARKING MANEUVERS
05-22-9
05-22-8
05-19-6
HARSH 2-3 UPSHIFTS 20-50 MPH (32-80 KM/H) OR HARSH COASTING DOWNSHIFTS 10-15 MPH (16-24 KM/H) - 3.0L WITH 5R55S
05-18-7
05-16-11
05-16-8
"CANADA ONLY" - MAP ZOOM - NAVIGATION SYSTEM WILL NOT ZOOM CLOSER THAN A 16 MILE SCALE (32 KM)
05-16-2
05-14-4
WRENCH LIGHT ON WITH BOTH DTC P2106 AND P2135 - VEHICLES BUILT 11/29/2004 AND PRIOR
05-9-7
STUMBLE AND/OR INDUCTIVE BACKFIRE
05-6-5
ROUGH IDLE OR MIL LAMP ON
05-3-10
05-3-1
MAF DIAGNOSTIC SERVICE TIP - VEHICLES EQUIPPED WITH EGR SYSTEM MODULE (ESM)
04-24-5
04-22-13
DIAGNOSTIC TROUBLE CODE (DTC) C1145 AND/OR C1155 STORED IN ANTI-LOCK BRAKE SYSTEM (ABS) MODULE
04-18-16
CLIMATE CONTROLLED SEATS TURNING OFF SHORTLY AFTER INITIALIZATION - DTC'S B2729, B2730, B2731
04-17-4
04-15-7
MOISTURE IN REVERSE LAMP
04-12-3
TRANSMISSION 5R55S - ILLUMINATED TRANSMISSION CONTROL INDICATOR LIGHT (TCIL) AND DTC P1744 ONLY
04-1-7
ENTERTAINMENT SYSTEM - AM RADIO INTERFERENCE - VEHICLES PRODUCED PRIOR TO 12/01/2003
03-23-2
03-22-7
BODY - TRIM - ASH TRAY DOOR WILL NOT LATCH CLOSED
03-20-3
03-18-1
03-17-2
BODY - INTERIOR - HEADLINER FALLING/UNATTACHED IN REAR - VEHICLES PRODUCED BEFORE 7/21/2003
03-15-8
TRANSMISSION - 5R55S - HARSH SHIFTS - VEHICLES BUILT BETWEEN 11/18/2002 AND 5/17/2003 ONLY
03-14-8
03-10-1
03-8-3
03-3-7
02-25-2
02-23-7
02-21-13
02-20-3
02-17-6
02-16-7
BODY - PAINT - APPROVED PAINT MATERIALS FOR WARRANTY REPAIRS
02-16-3
________________
2004 TSBs
- US (English)
09-12-12
08-16-5
08-12-4
07-12-3
07-5-8
07-4-3
07-1-7
06-25-15
06-25-13
06-21-19
06-18-16
06-15-8
06-5-16
05-22-9
05-22-8
05-21-8
DELAYED OR HARSH REVERSE ENGAGEMENTS - 5R55S TRANSMISSION - VEHICLES BUILT PRIOR TO 09/23/2004
05-19-6
05-18-7
05-16-11
05-16-8
05-16-2
05-14-4
05-9-7
05-9-3
INTERIOR PLASTIC TRIM - PAINT-TO-MATCH AND REPAIR - INTERIOR SPRAY PAINT AND ADHESION PROMOTER USAGE INSTRUCTIONS
05-6-5
05-3-10
05-3-1
04-24-5
04-22-13
04-18-16
04-17-4
04-15-7
04-9-6
BODY - PAINT - IRON PARTICLE REMOVAL - INDUSTRIAL FALLOUT - ACID RAIN NEUTRALIZATION
04-1-7
03-23-2
03-18-1
03-17-2
2005 TSBs
- US (English)
09-12-12
08-16-5
08-12-4
07-12-3
07-5-8
07-4-3
07-1-7
06-25-15
06-25-13
06-25-1
5R55S - LEAK FROM CONVERTER HOUSING - FLUID OVERFILLED
06-23-17
3.9L V8 UNUSUAL ENGINE NOISE - SPARK KNOCK / TICKING NOISE UNDER ACCELERATION
06-21-19
06-21-7
AUDIO / NAVIGATION SERVICE AND ORDERING PROCEDURES
06-18-16
06-15-8
06-5-16
05-22-9
05-22-8
05-21-8
05-18-7
05-16-11
05-16-8
05-16-7
SQUEAK IN AREA OF DOOR LATCH
05-16-2
05-14-4
05-10-20
BLOWER MOTOR INOPERATIVE
05-9-3
05-6-5
05-3-10
05-3-1
04-26-16
WELD BONDING PROCEDURE
04-24-5
04-22-13
04-9-6
2006 TSBs
- US (English)
09-12-12
08-16-5
07-12-3
07-5-8
07-4-3
07-1-7
06-25-15
06-25-13
06-23-17
06-21-19
06-21-7
06-18-16
06-15-8
06-10-5
5R55S - TRANSMISSION FLUID LEAK
05-22-9
05-22-8
05-18-7
05-16-11
05-16-8
05-9-3
01-10-12
Just started with this on my 01 sport.. Harsh upshift after like yielding. Blahh!
02-6-6
03-3-4
03-3-5
Much appreciated Joe!
01-10-12
Too big to post here, PM me with e-mail address
02-6-6
03-3-4
03-3-5
02-06-06 is attached. Send me PM with e-mail address for the other two (too large).
PMed. Figured that'd be an easy fix, I'm going to take my tranny in for a drain/refill/filter after reading that. Transmission acts fine but better to be safe when I can't really check the levels.
You have a way to pull TSB via year/VIN? I don't really have a symptom code just curious.
Tsb 06-23-17
Just had TSB 06-23-17 applied to my 06 LS (for a 1 hour labor charge).
TSB: 3.9L V8 Unusual Engine Noise - Spark Knock / Ticking Noise under Heavy Acceleration.
Covers: 2005-2006 Lincoln LS
This will basically retard the timing 2 or 3 degrees to eliminate pinging.
I use 91+ gas, but I still got the pinging before even with subtle acceleration. The pinging appears to have been elmininated and I have not noticed any significant decrease in power or increase in fuel consumption.
I've got what sounds like injector noise. Wanted to see if there is a TSB out for it. I've got an '06 Sport. It did seem to go away after I ran some Lucas Snake Oil Fuel Treatment through it :P
But, that was only 1 tank ago. Guess I'll see if it comes back.
I can pull them by year and model, but not by VIN.
I won't be able to respond to more TSB requests until this evening.
I had the pinging on 93 gas for a while, but I was able to realize that it only happened when I got gas at one particular station. I had the state test the gas there. They said the octane was okay but that it had very high water content. I stopped getting gas there and no more issue.
