tripminder
younggunmarkvii
Northborough
I just bought a 1992 Lincoln Mark VII and my tripminder does not work i was wondering if it was a fuse or do i just by a replacement one? all feed back is welcome
There is a 5 amp fuse that runs the tripminder, it should be the only 5 amp fuse in the panel unless one has been replaced with the wrong rating. It should be a tan colored fuse.
thnx
Hey thanx for the info its greatly appreciated
younggunmarkVII
If all your fuses and power checks are Ok take the unit out and
clean the connections on the back -- good tech article at Lincolnsonline.com
about doing the tripminder tuneup -- If all else fails replace unit
-- none available from Ford but if you do wind up needing one llet me know
I have stashed a couple spare units away that work great and would be willing
to part with one ---
hey thnx walt for the info its really appreciated.
younggunmarkvii
