transmission
ladenblowfish
Greer, SC
I'm needing to replace my transmission in my 93 mark. I found a low mile trans out a 01 gt. Will it fit with no problem? What parts will have to be replaced? What year mustang trans will fit in my mark?
It will fit. Just need to modify the pins on the harness that plugs into the transmission, use the TCC made for your year car (must be modified via dremel to fit the 01 tranny), get a new MLPS for your your car and an Orange speedo gear (I may have an extra one). Also check out TCCO.com I plan on doin the swap someday lol, I have the trans from a 2002 Mustang, TCC, need to get a new MLPS and figure I will get O2 sensors and IACV while the trans is out.
http://www.cardomain.com/ride/496399
http://www.p71interceptor.com/tranny/diagrams/electrical/external/bulkhead/index.html
repinning the harness.. and modifying the TCC plug is very easy.
I was very worried about this when I stuck the 98 trans in my 95.
in the end.. it wasn't as bad as I had imagined..
