mrhague said:
I have a 2004 LS automatic with low miles. Ever since I got the car, it shifts hard into third gear. All the other gears are normal. It was getting worse, so I took it in. The dealer replaced many parts, but the problem continues. Is this normal? Thank you
You should take it to the dealership, just in case, so it'll be documented, but give it some time.
I had a similar complaint with mine when I first got it, but it just took the car some time to learn my driving style. That's the beauty of these electronic monsters; it takes some time, but they adapt to you, rather than you having to adapt to them.
It's still not perfect at times (sometimes it'll hit a gear hard if I back off after getting on it, and I want the damn thing to downshift when
I want it to downshift, not when the computer gets around to it), but it's improved tremendously since I took delivery.
FWIW, it had 14.5K miles on the clock when I bought it in March, and it now has 22.3K miles, but it only took a few weeks for it to improve itself.
BTW, how's the manual tranny swap coming, JES?
