Transmission problem? HArd shift then a drop in rpm's
91300zx
RI
So my 04 LS V6 has started acting a little strange. When its shifting into first it shifts quick and hard I guess I would call it. It makes a clunking sound. Then when the rpm's are at about 2-3k they will drop slightly then pick back up. Seems to only happen when shifting into 1st as I haven't noticed it in any other gears. Any suggestions would be greatly appreciated. No codes or lights are on. Was going to start with a transmission flush since Im not sure if it ever had one. Coils and plugs were done about 7 or 8 months ago. Thanks for reading
Does it sometimes jerk into reverse?
Probably the solenoid assembly.
Now that you mention it yes it does jerk in reverse. I'll put it in reverse and it will take a few seconds then finally go into reverse with a jerk. Is this something that someone with average mechanic skills can replace? Do I have to open up the tranny for this?
Yes, if they are able/willing to look up the specifics on the LS.
Yes, the solenoid assembly is inside the transmission. The pan has to be dropped, but the transmission remains in the car.
Sorry for the dumb question but what kind of specifics. Thanks for the input joegr. Would you recommend all data for specifics?
All kinds, specific instructions on how to do it, torque specifications for putting it back together, which fluid to fill it back up with...
Staff online
