Whats the OEM transmission o-ring dipstick size?
whats the best size to use to prevent leaking?
I brought a kit with sizes 5mm - 14mm id x 19mmod x2.5mmW
It's a standard, not metric size. Also the same size as the oil dip stick o-ring. 5/8 I beleive...just take one with you to any parts store and match it up
Ok cool i'll wait til tomorrow to get the right size that one screw on the dipstick is a real pita. I hate I have to take it back off.......... Mine is leaking around the dipstick I was tryna use some permatex to stop it but is was a Fail.
Thanks alot and Merry Christmas
There are tons of screws on these cars where gear-wrenches are a near must, this is one of them. With a 10mm angle or flex head, you can get it easy from the bottom, with gear on the head, handle pointing towards trans, no problem
hell yea i found out awhile ago i brought a set from Pep Boys for $29.99 sizes 8mm-19mm.
I used a 10mm for that screw but it was still a pita and even more of a pain when i realized after i changed the o-ring. I used the wrong size and it was still leaking
