Soon I will be installing a 99 4R70W into my 93 Mark 8.
I have the 99 trans and am waiting on a separator plate kit from BOC.
The junk yard said it had 36k on it and when I removed the pan I found the dipstick widget... plus the fluid looked pretty clean.
Is there anything I should so in the mean time to check this trans out and make sure everything is alright?
I have a replacement TCC solenoid - how do I install that with the circuit board style wiring? (I'm sure it's obvious but I don't want to screw it up)
I'm also getting an Art Carr converter soon. How do I install that? Does it just click into place? Any tips and tricks would be helpful there.
Finally - Should I have a shop do this? I was quoted $350 for the job, but money is getting tight and I was thinking I could do this myself. Then again, if i screw it up it's my own fault.
Thanks!
Thanks!
