Tourque spec.
Slide pin bolts - 26 ft-lb
Anchor plate bolts - 76 ft-lb
(True for front and rear)
And, if I may, make sure you use loctite if you reuse the anchor bolts. I just spent a week or more chasing a suspension clunk that ended up being my rear calipers being loose...the anchor bolts needed tightening and torquing.
