Here this may help:
Item Part Number Description
1 4B477 Axle shaft nut
2 W520213 Toe link outboard nut
3 W705517 Toe link outboard bolt
4 W500014 Wheel speed sensor bolt
5 W705518 Lower arm-to-wheel knuckle nut
6 W705516 Lower arm-to-wheel knuckle bolt
7 W520214 Upper ball joint nut
8 5A968 Wheel knuckle and wheel hub assembly
9 — Speed sensor retainer clip (part of 2C190)
10 W520214 Upper arm-to-subframe nut (2 required)
11 W704887 Upper arm-to-subframe bolt (2 required)
12 5500 Upper arm
13 W520213 Stabilizer bar link lower nut
14 5C486 Stabilizer bar link
15 W704884 Shock absorber lower bolt
16 18125 Shock absorber
17 W520215 Lower arm-to-subframe nut (2 required)
18 W704886/ 704888 Lower arm-to-subframe bolt (2 required)
19 5A649 Lower arm
20 N807144 Toe link inboard nut
21 5B551 Toe link
SECTION 204-02: Rear Suspension 2006 Lincoln LS Workshop Manual
REMOVAL AND INSTALLATION Procedure revision date: 06/24/2005
Toe Link Printable View (10 KB)
Removal
CAUTION: Suspension fasteners are critical parts because they affect performance of vital components and systems and their failure can result in major service expense. A new part with the same part number must be installed if installation is necessary. Do not use a new part of lesser quality or substitute design. Torque values must be used as specified during reassembly to make sure of correct retention of these parts.
NOTE: The toe link retainers are of a torque prevailing design and new bolts and nuts must be used during installation.
1. With the vehicle in NEUTRAL, position it on a hoist. For additional information, refer to Section 100-02 .
2. Remove and discard the toe link outboard nut and bolt and disconnect the toe link from the wheel knuckle.
To install, tighten to 55 Nm (41 lb-ft)
3. NOTE: Use the hex-holding feature to prevent the toe link ball joint from turning while removing the nut.
Remove and discard the toe link inboard nut and remove the toe link.
To install, tighten to 70 Nm (52 lb-ft)
4. To install, reverse the removal procedure.
5. Check and, if necessary, align the rear end. For additional information, refer to Section 204-00 .
