Swirl marks are inevitable with any daily driven car. You cannot prevent
them short of storing your car since the the day the paint dried.
Swirl marks are caused by agitating course debris over the paint
finish that have accumulated on the cars' surface. It is compunded either
by a number of reasons. Some are caused an automated car wash, a dirty mitt
or chamois, a dirty car cover, use of a rough dry towel or even using
the wrong polishing compound and harsh abrasive cleaners.
Failure to remove dirt, grime and other damaging particles before the
waxing stage will further create more micro scratches or swirl marks as
you rub the particles into your paint finish.
When washing your car, you must do it in the shade away from
direct sunlight. I normally wet my car early in the morning for a few
hours prior to shampooing. This method softens and loosens the caked
on debris ahead of time thereby allowing me to shampoo the car applying
as minimal pressure as can be to the paint as I work to loosen and remove the
debris using my clean synthetic chamois. Shampooing my car after rain
also works great as rainwater moistens and loosens up any debris.
Swirl removers can be used to remove deeper swirl marks but be aware
that it will remove a thin layer of your clear coat. Use it sparingly.
Most swirl marks can be effectively masked using a good carnauba wax
and polished to a nice flat reflective surface.
For best results, have a skilled pro apply wax and polish for you. If you
are confident enough, you can use a good foam pad wax applicator on
a dual action orbital polisher. Pay close attention as not to burn the
paint at corners and sharp edges.
Oh yeah, Option 2 is best.
Ren/Octane
