um, NO!
The manufacturer of the tire knows nothing about the car, all they know is the characteristics of the tire, like the maximum safe inflation pressure and the maximum load. The maximum inflation pressure listed on the sidewall is absolutely not in any way a recommended inflation pressure.
In addition, the inflation recommended in the door jam is not universal, that is, if you change tire size (and the OP has done that), then you cannot blindly apply that tire pressure as being correct. You will note if you take a look at the label, that it lists not only a pressure, but a specific tire size as well. The listed pressure is for that size tire.
