Thermostat help?
Xrumer
Michigan
I went to the store today and noticed i didn't hear the heat blowing when the setting was on high... So i turned off the radio and moved the fan speed up and down and noticed i wasn't getting any response. So i turned it on and off changed direction settings and still nothing.
What does happen is that if i put my hand up to the vent its barly coming out however its still hot. So it not a heater problem i'm thinking.
Any help?
rember to keep it simple, no air flow=no blower motor operation. blend door is lack of good heat (trust me i know)
there's a wire that goes to the blower motor, under the glove box. I think its a black and orange wire. Usually if you move it around you can get it to work temporarily but basically what happens is the connector gets screwed up and isn't making a clean connection. There's a way to fix it but I'd just order a new one from Max at 5 star
Whats the average cost? Is their instructions posted online on how to replace it?
Thanks! It's cold as hell out there!
