The day I was dreading has come ( 2003 LS8 skipping)
Farking Bastage
FL
I figured this day would come to pass eventually, but I am not 100% sure how to tackle it.
I have a 2003 LS8 with 80k miles. It has run like a top since the day I got it, but I started having a little skip at certain times that has now manifested itself into a problem. For about a week now, it has started jerking under mid acceleration. I figured there was a coil about to go somewhere, but when I took it in, no one could find a code, it was misdiagnosed as a torque converter hesitating to lock up and I walked out with a tranny fluid exchange.
The problem continued, although most of the time I knew how to manipulate it not to act up, but didn't mess with it mainly for lack of time to deal with it. Today it scared me.
Accelerating around a corner on the way home, it started the jerking between 40-50 MPH and 2k RPM, then I suddenly lost all power, the AC stopped, the check engine light flashed on and off about 4 times, then it came back to life, almost as if the computer said "f-it" and rebooted. ( sorry I work in IT best I can describe)
Steps to reproduce:
Get it good and hot, it usually is fine when cold
Put the engine under a load at around 2k RPM ( usually 40-50 MPH in normal driving) and if you listen very carefully, you can hear it skipping. It feels like an indecisive shift, but you can clearly hear the engine skipping.
This happens in both Auto and SST modes and I can reproduce it at low speeds by putting it in 4th or 5th and giving it about half throttle.
It happens under light to medium throttle right in the 2k range. Once it's above that, or of I am standing on it, it's not as noticeable.
Everything I have read on here and elsewhere points to the ever-notorious coil.
My questions:
If it is indeed a coil, how would I determine which cylinder it is? I'd rather not buy a full set at this time if I can help it. I am capable of changing them myself.
The Check engine light went away. I am assuming the computer logs faults to be read at a later time. Please correct me if I am wrong.
Would your chain variety auto parts store be able to read the codes off this thing if there are any to read? I'll take it in if I have to, but no need in doing so if not necessary.
This car is, to the best of my knowledge, on it's original set of coils. Would a failure at 80k without any other signs justify new VCG's?
Thanks for taking a look and thanks for the wealth of information you have here.
