The 20's Rub on the back!
The higher the better. Don't the rear S Type R 9.5" have an offset of like 60? Those fit pretty well perfect from what everyone that has them says.
+42mm or higher if you want an 8" or 8.5" width (never looked into anything wider) for a 19 or a 20" wheel. You can get by with a 38 offset on an 18 - there's been a few guys on LVC with 'em.
TRU
To run the jag s type r wheels, I believe we need 4 fronts. IIRC, the rear wheel offset is like 25mm or something.
why do SO many posters who get 20 inch wheels and higher ALWAYS end up coming back with rubbing issues? WTF. Who doesnt do a LOT of research before doing mods like this. Bigger wheels have heavier weights...which all equal reduced peformance, slower accleration, longer braking times, etc
Im taking it to a bodyshop to get the lips rolled the right way.I already have diffrent brake pads and the cross drilled slotted rotors off LSkoncepts The cars dyno tuned No excelleration problems and I even programed the corect tire size in with the programer so my spedo isnt off! I did some research granted not much of it was on here everyone i talked to said they would fit no problem.And that they do untill i to many people in the car and i hit dips! I blame it on nebraska roads!
