Medone
I just wanted to thank everybody here for helping out with other peoples problems. I have been searching posts here for a few months, I purchased a barely running 00 LS. To make a long story short, without this forum the car would not be running today. I made a list of what was wrong with the car below.
*5 of the Cops were bad
*P0402, EGR valve gasket was missing
*Both valve cover gaskets were leaking
*Passenger secondary timing tensioner was worn and about to break. I replaced both secondary tensioners using the timing lock set on Ebay without removing the front cover.
*Fuel filter was plugged
*Lower ball joints bad
*Drivers side front wheel bearing noisy
*Rebuilt starter due to a clicking noise (new solenoid/brushes)
*Drivers side airbag connector wires broken
*Clock spring bad
Again, Thanks!
*Clock spring bad
Again, Thanks!
