System effects on alternator/ hid difference
Lownslowlsc
N il
Curious. My 98 marquis would dim horribly with the existing amp that im using. Amp current draw is 120-130 amps. Marquis and the Mark both have original alt's and are both 130-5a's. Both int/ext lights of the marquis were bad. The mark only the int dims slightly. Headlights/ taillights show very little if any dimming. I would think since the mark requires more power to run the do dads that it would be worse.
Do the hids and neon have anything to do with the lights dimming at all? Iirc the hids require less power to function then reg holo's
Using the same 1000ca/850/cca battery. No big 3, ect.
The HID's and Neon shouldn't really dim since they have there own amplifiers. At least the HID's do. The Neon is a different but similar kind of deal..:confused:
