Sway Bar Links---HELP!!
cammerfe
Metro Detroit
Does anyone have the old links laying around after replacing due to rubber failure? I have a mind to try casting polyurethane into the metal 'dogbones' if I can easily find some of the metal parts that are undamaged.
Reply here or PM with info!
KS
KS
How soon would you like these?
To Dan and Dis---
This is one of the things that need to be done before the real start of summer. If you'll have some laying around with the metal part good, anytime soon will be just fine. Goodness knows, I have lots of little jobs to tend to!! And Thanks!!!
KS
To Dan and Dis---
KS
Well, it sounds as if Dis is doing his before I am. I was actually planning on replacing the rod in the dogbone of the links with a thicker rod.
