supercoupe suspension
1sik32v
socal
Just got the fronts installed waiting for the next check in order to do the rears....my rear bags don't wanna pump up now they did twice but it doesn't want to send the air to the back bags now....
Sounds like a good plan.
I'd also want to take the super coupe front seats.
How are you going to wire up the automatic ride control solenoids? I had a 1987 Mustang with '88 Turbo Coupe electronic shocks and struts. I wired the solenoids up to a rocker switch on the dash to switch between soft and firm. It worked pretty good. That 'Stang also had the rear end with disc brakes as well as the sway bars and front seats from the TC. So do you plan to use the adjustable shock feature on your Mark?
They r the adjustable I'm just goin to leave it in the firm position a 1/4 turn clockwise to make it firm and then 1/4 turn counter to make it soft again.....I do a lot of mountain driving so I like it firm then wen I hit the track soften them up to get weight transfer so yeah
Oh and the backs pump up still but its temperamental as hell
^^im having the same problems with my front suspension. are you running the stock compressor? check out your airlines where they go into the comp.
Everything worked well before I did the swap just did prevented maintenance so wen I let it sit over night.....the a$$ is on the ground i go fire it up the rears pump up and will stay up till I get home from work..... idk its not bothering me but I hope that supercoupe is still there wen I get my next check.
