Stupid Brake questoin of the day
chris
Phoenix
When bleeding the brakes after a master cylinder change is there a special procedure for the ABS gizmo, or can I just bleed it like normal? Thanks for the help.
Presuming that you pre bled the MC you can proceed to bleed the rest of the system. Just remember that you bleed the PS rear then the DS front, then DS rear and PS front as this is how you need to bleed ABS brakes. Dont let the chambers go dry. I use Super Blue Dot 4 for easily knowing I have all the old fluid out of the system.
You are supposed to use a scan tool to active the pump and flush the fluid in the ABS pump, but RoadBoss has the process nailed above.
I got mine with the ABS removes by the previous owner because it was giving him problems. Been driving this thing for years now and haven't felt a need to put one in.
