Karma Killer xx
Hello to everyone at LVC. I have been lurking here for a few weeks. I finally purchased my '04 LS V6 less than a week ago and I'm in love. I got her from the dealership I work at- she was slated to go to the auction and I simply could not let that happen. I digress.
I've been trying to solve my A/C issue day by day.
The issue:
The compressor cycles way too often (especially since the compressor shouldn't really cycle much at all with this system). The compressor will come on for about 20 seconds then turn off for about 20 seconds (give or take a few seconds). When the compressor is running, the air through the vents feels cooled but not cold, about 70 degrees at idle and a few degrees cooler while driving on the interstate. Obviously the air from the vents should be much colder, but I figure the compressor running for only 20 seconds isn't allowing the air to get cold. This happens on both Auto and Manual adjustments.
What I've tried:
I work in a shop and have access to a Robinair A/C machine. I evacuated, vacuumed, and recharged the system to 28oz as recommended by Ford. Same issue, no change. I added a few ounces, one at a time to see if the system needed any additional "Suva", no change. While adding, the pressure of the high side (when the compressor was on) went from about 150 to over 200 as I added more R134a. No change (except I think I added more than she wanted because the air, while the compressor was running, wasn't blowing as cool as it was with 28oz) I then decided to evac, vacuum, and recharge to 24oz and slowly add Suva oz by oz until I reach 28oz. No change. The compressor still cycles often. I did an onboard diag via the interior A/C unit (DATC?) and received a 1265 - Cool Air Blend Door, which I've read on here and other places that it is not equipped on this vehicle. And SOMETIMES when I do the test I'll get a 2798, which is an issue with the DCCV. I say sometimes because I've done the self-diag about 15 times using both the stored and current options and have only received the 2798 twice. This may mean that my DCCV is hiccuping, but I highly doubt it is causing my current compressor cycling issue. Also, all of my vents seem to blow the same on and off "cooled" then "muggy" air. No heated air- and the heat does function very well when I've tried it.
My last though is that it might be a faulty Pressure Gauge. I tried unplugging it, and the compressor will not come on, and my fan speed increases significantly. I believe I can jump the connector using a 1.5v battery, but I haven't tried this and I'm not sure I want to.
If any more information is needed let me know. And thanks in advance for actually reading all that
The issue:
What I've tried:
