starter or other problems need help
jumpball207
Miami
recently ive been having a problem with my ls when ever i try to start the engine it doesnt start the engine doesnt even turn and then ussually after 3 or 4 times of trying the engine will start up easily without struggle or any problems.The battery is brand new could this be a problem with the starter or something else
the electric componets on the dash turn on along with the ac just fine but the engine doesnt make a sound and befor it just wouldnt start up after 4 or 4 trys no i have to try like 20 times to start it up but theres no clicking of the engine or nothing i just turn the key and nothing happens
i havent personally looked at the start system but I will check alldata.com in a bit to see what is involved. However, isnt tehre a start solenoid on most cars?
I know it might sound stupid, but i wonder if your having problems with the pats key. Check and see if the red light on the dash goes on and off again when you put the key in.. Would you still be able to turn the key over if it was going bad though..
not stupid at all. I think this has occured before maybe even a tsb on it. Most of the pinpoint test are centered on voltage to the starter or solenoid, checking the contacts, PATS/anti-theft system etc.
Check the battery for corrosion. The pin point test has a lot of steps and requires a volt meter and remote start switch. It might be worth taking it to the dealer and have them troubleshoot the problem and you make the repair if you have some basic tools.
That is exactly what I was thinking should have it looked at.
