SST Shifter
pelphrey
Kentucky
I have an 02 V8 with the regular D5 then to the right and down D4, 3, 2, 1. Can I add the SST shifter to my car and have it work correctly? Any input on this would be appreciated.
Thanks
Yes and you will have to get the car's computer reflashed so you can use it, from what I understand. Also, in order to start in '1', you'll need to have a custom tune done allowing it, otherwise it'll start off in '2' while in SST.
There's a write-up around here somewhere. Try the search and see if it brings it up.
i just did mine about two weeks ago and it was one of the easiest upgrades i've ever done on a vehicle. you don't need a reflash to make it work correctly, you only need it if you want to be able to use D4 still, when you shift the shifter into the D4 spot it goes into 3 .. but i don't get the point of that because you could just go into SST4 instead...
You DO need a custom burn to start out in first gear in SST mode though, just like all SST gen 1 LSs just search the site for the swap PDF
http://www.lincolnvscadillac.com/showthread.php?t=13846
there's the really good write up, the only little detail missing is when re-hooking the cable to turn the key to on in the ignition without turning the engine on and making sure the Gear readout on the display matches where the shifter is in position before locking it together. it'll make sense once you look at it.
