smegun
shifts ok but when using the sport SST mode there seems to be a skip when downshifting from 3rd gear it seems like it wants to shift all the way to first noticeably any down from 3rd is delayed too long to engage and when it does finally shift it seems very high like it made it to first instead of second causing excessive rpms and familure 1 gear decelarant noise
I avoid it and break harder probably the only reason to shift though making ground out the hole or otherwise sporting 2nd and third I figure it has something to do with the way they set up starting out in 2nd not fond of the issue altogether up or down but this issue is unkown except for 1st its always a high rpm parabola
not cool
