Do it yourself!!!! Putting your own springs on is a nice simple + fun job for the weekend, we did it last week to my buddies 350z.
Ill see if I can make time to help you. I have a warehouse available on the weekends full of tools. With two people it would be quick. You then need a front wheel alignment so you dont chew through tires every 5000 miles.
I did mine with hand tools. No airIs it really that easy to DIY? What kind of tools do you need?
and on an added note, you should actually get a 4-wheel alighnment (yes, the rear is adjustable)
No alignment necessary.
Impossible, I am on my 3rd lowered Lincoln LS. 00/02 and now 04. Have used Eibach in the 1st setup, Sprint in the second and Intrax on my third. All have needed alignments due to the inside of the tires being completely shredded after a few thousand miles.
Its mostly toe, not the camber. When you lower your car the wheels go outward causing inside tire wear. <- ->
