The only other things to be aware of are the shock bolts and the lower control arm bushings. They should be able to tolerate the impact. Pay attention to the positioning of the lower control arm bolts where they mount to the crossmember, as their position affects camber and also caster (don't quote me on that one) and also, use the impact wrench only on the nuts if you can, and hold the bolt heads with a suitable wrench. I don't know for sure, but on my Marauder, those LCA bolts are actually offset and are used to set the alignment, so when they turn, the bushings should wobble in an orbiting fashion. I can't recall whether the LS has the exact same setup from the factory, but if they do, and you can get to the bolt heads with that impact wrench, they will be wiggling in orbital madness. Good luck. Hopefully, I saved you some ball joint boots.
