Sound System
CrackerJack
Minneapolis
I have the Alpine 6 CD Changer, I would like to know what kind of speakers are in the back, are there actually subs along with standard 6x8's?
Im totally confused, as nobody online has anything.
Yes, they are 6x9 "subs", run by a separate amp located under the rear shelf. I forget the power of the amp itself. If you get an aftermarket head unit, you might want to just get a sub instead of trying to keep those 6x9's. I've heard people have had trouble with them when adding an aftermarket HU.
Yeah definatly want to go aftermarket, would save your self a huge headach, and be able to alot more.
ahhh, so how much issues would I have installing a new deck?
I really want the Auxillary port / USB port so I can use my Zen X-FI Player... but I only have CD's... whih cost even more cash to give out >.>
also, where is the antenna for radio? inside the frame by the rear window?
you can get what is called a premium wiring harness for the LS. it will give you the capability to keep the stock subs with an aftermarket head unit. not much extra work. Good luck, just keep the stock subs and then justify if its worth the extra money to put a quality sub and box setup.
installing a new deck is very easy, and yes the antenna is in the rear window
