Has anyone done, or heard of, or is planning on, or knows how hard it is, or how practicle it is to do a solid rear swap on the mk? What rear would we use? does the t-bird or coug have solids? or would we use like...a rustang gt's rear?
Frogman said:This topic was already covered several days ago, right here in this forum.
MrWilson said:actually....that was about the cobra IRS swap, im looking at a solid rear...staying away from the IRS all together. Unless im looking at the wrong spot again
ONEBADMK8 said:Believe me I will challenge you to break it if thats the reason you were going to give.
ONEBADMK8 said:Why on Earth would you want to backpedal into the stoneage and go with a solid rear?
Lose all that nice ride..etc.
All the Marks we have ever done in 8 years, we have only ever once broken ONE rear part and that was a CV joint that had 180k. Belive me Andy put your money elsewhere in the car.
rocket5979 said:Ummm.....maybe because a solid rear can launch one heck of a lot better than a IRS vehicle. Also it seems that Wilson has some fairly large plans in the future for his Mark. If he will be making anymore than 500rwhp or so then it would be good to either go with a custom DSS halfshaft setup on his existing IRS or swap to a solid.
Heck Wilson why not just go with a 4 link rear with solid axle while you will be back there. Gives the decent ride and superior weight transfer ability for launching.![]()
ONEBADMK8 said:LOL The IRS is BORN to drag race. Squats like the devil and transfers weight perfectly.
torquemonkey said:For the amount of energy, money and time, why not get a car that is already set-up with right suspension? You could drop the mill of your choice into it.
MrWilson said:and snaps half shafts like a mofo!
because no other car is a Mark8
ONEBADMK8 said:You must be deaf or just do not pay attention.
Ill say it again, in 8 (eight) years I have only seen one cv joint break and that was with a car that had 180k on the body along with NOS 150 shot and slicks.
STICKS break them NOT autos!!!!!!!!!!!!
True that the T-56 is the king of breaking drivelines, but power is power. Worst comes to worse, a 31 spline swap may be in order. We will see what happens though. No use in arguing a moot point.ONEBADMK8 said:You must be deaf or just do not pay attention.
rocket5979 said:BTW Wilson what do you have planned?
MediumD said:How come Cobra guys do a solid rear swap when they're building a drag only car? How come the Supra guys blame IRS when they can't hook?
MrWilson said:a whole lot of fun. Its a shock and awe campaign.
Its along the lines of the FR500C
rocket5979 said:Ohhhh..... DOHC 5.0 Stroker with cams....Nice! It should make some pretty decent power, though probably not enough to cause a lot of breakage in your stock IRS. That is, unless you use a transmission with a transbrake in it.Any possibility of F/I in the cars later future too or sticking with N/A?
MonsterMark said:Port and polish our heads and they flow as good as any of them out there.
