drained radiator,flushed radiator,drained,fushed a 2nd time,drained,filled with distilled water ran and drained.
changed out the dccv and degas refilled following bleeding instructions and got a gusher out the bleed hose.
today i decided to bleed 1 more time and all i get is a trickle. my ac and heat both work thru all temp cycles left and right side.
do i need to bleed til i get a gusher again or you think i'm good to go.
as always thanks greatly
