smoke in warm weather
ZWilson07
West Point
so i noticed tonite. its only lik 65 or 70 degrees but wen i got out to check my air pressure on my tires an left the car running i noticed alittle bit of whitish grey smoke coming out of the dual exhaust. not alot but enough to where i saw it floating above the trunk. is this bad sign or just cause it was cool out. its about 5 am right now. its an 03 v8 with only 80'000 miles an has all the fluids changed about 1000 miles ago
Yeah, the exhaust runs fairly hot, so any moisture inside or outside the exhaust will BURN... err, evaporate... Plus grease and junk on it too so more like BURNNN
