Senta rims on an 04' LS Sport
2FAST4U
NOVA
I absolutely love the jaguar Senta rims. Can anyone tell me if the OEM setup works with a stock 04' LS?
They are 20 inch rims with an 8.5 wide front and a 9.5 inch rear
How bad does it affect the ride? Can the ECM be programmed for the new wheel size to calibrate the speedo?
The rears wont fit. You have to get all 8.5's
I think you will want spacers up front too
The fronts are 20X8.5 with a 49 MM offset. The rears are 20X9.5 with lika a 23 MM offset or something crazy like that. As Starfox86 Said you would need four fronts. There are a couple of guys on here that have them. As far as affecting the ride, I would say a stock OEM rim would be more durable than aftermarket. Tires are where the difference can really be felt.
the ride gets pretty rough when you ride on 20s. i mean its still smooth but you can def feel it a little more. only advantages are getting some hi performance tires on em and hittin them corners goin like 60 and not skidding out of control . other advantage is how nice they look on the ls. you should also be able to program the car but i havent done that yet. i still need to buy the sct.
